Back to API
Works with Flex
A radio that plays well with others
Software and hardware from independent developers that connects to FLEX-6000, FLEX-8000 and Aurora series radios. Each product is built and supported by its developer, so follow the link to download it, read its documentation or ask its maker for help.
Station hardware
Amplifiers, tuners and switches that talk to the radio over the network.
Product What it does Learn more
Power Genius XL 4O3A's legal-limit, 1.8 to 54 MHz amplifier, rated 1500 W at full duty cycle and built for SO2R. 4o3a.com ↗
Tuner Genius XL 4O3A's automatic antenna tuner, built for single-radio SO2R. 4o3a.com ↗
Antenna Genius 8×2 4O3A's smart antenna switch for eight antennas and two radios, built for SO2R and multi-op stations. 4o3a.com ↗
HamCore 6×1 / 6×2 SO9I's remote antenna switch, controlled from any browser, with WiFi. It reads frequency and PTT from the FlexRadio over the network to pick the right antenna automatically. so9i.com ↗
Radio clients
Software that runs the radio itself, as an alternative or companion to SmartSDR for Windows.
SmartSDR for Mac The SmartSDR client for macOS from Marcus Roskosch, DL8MRE. Operate FLEX-6000, FLEX-8000 and Aurora radios at home over your network, or from anywhere with SmartLink. apps.apple.com ↗
SmartSDR for iPad and iPhone The SmartSDR client for iPad and iPhone from Marcus Roskosch, DL8MRE. Works with FLEX-6000, FLEX-8000 and Aurora radios locally or remotely through SmartLink. apps.apple.com ↗
DogparkSDR A native macOS client for FlexRadio transceivers from Dogpark Software (VE3VRW), the makers of MacLoggerDX. dogparksoftware.com ↗
AetherSDR An open-source, native client for FLEX-6000, FLEX-8000 and Aurora radios on Linux, macOS and Windows. Adds GPU spectrum display, DAX, client-side noise reduction and built-in data-mode tools. aethersdr.com ↗
RimuSDR A native client for FLEX-6000, FLEX-8000 and Aurora radios on Linux and Windows. Includes RimuDAX audio routing and RimuCAT CAT control in one suite. rimusystems.com ↗
PocketSDR for Android A SmartSDR-compatible client for Android phones and tablets. Works with FLEX-6000, FLEX-8000 and Aurora series radios. play.google.com ↗
ZeusSDR A WebGL station console for Windows, macOS and Linux, built for OpenHPSDR radios. Its FlexRadio edition, Zeus Link Flex, is currently in alpha. zeussdr.com ↗
Control, automation and utilities
Tools that add controls, automation and information alongside SmartSDR.
ControlDeck A touch control surface for iPhone, iPad and Android that runs alongside SmartSDR. Hot keys, VFO tuning and macros on your local network or over SmartLink, with no extra hardware. controldeckapp.com ↗
SliceTCI A TCI server for FlexRadio on Windows, so TCI programs such as WSJT-X can control a slice. Audio comes straight from the radio, so SmartSDR DAX and the Windows DAX sound devices are not needed. va3mw.github.io ↗
FRStack A Windows companion to SmartSDR that lists active slices, recent frequencies and memories. Also works with the Power Genius XL, SPE amplifiers and SteppIR antennas, and offers a REST API for Stream Deck control. mkcmsoftware.com ↗
Slice Master 6000 Configures and launches third-party programs such as CW Skimmer, WSJT-X, JTDX, MSHV, JS8Call and fldigi for each slice. Also runs skimmer servers on each DAX IQ channel. github.com ↗
SliderMaster Adjust DSP levels for NB, NR, ANF/APF, WNB and the newer DSP features from simple sliders. Handy on M models and Maestro, where these settings sit deep in the menus. ve3cko.itch.io ↗
FlexInfo Shows radio voltage, temperature and the active Global Profile in a small window that sits on the SmartSDR title bar. Works with FLEX-6000, FLEX-8000 and Aurora radios. github.com ↗
Flex Repeater Spots Places permanent spots on the SmartSDR panadapter showing FM repeater frequencies and names. Clicking a spot applies that repeater's stored FM settings. github.com ↗
SmartSpotter Sends WSJT-X decodes and DX Spider cluster spots straight to the SmartSDR panadapter. Works with FLEX-6000, FLEX-8000 and Aurora radios in all modes. github.com ↗
SliceAPRS Listens to 2 m APRS through your FlexRadio, works out which stations you heard directly and alerts you when the band opens. It is receive only and never keys the radio. va3mw.github.io ↗
FMT Assistant Software for the ARRL Frequency Measuring Test that runs beside WSJT-X on test night. It keeps the clock, prompts you by voice, checks the WSJT-X measurement files for common mistakes and works out each carrier frequency, ready to submit. va3mw.github.io ↗
Morconi A network interface for remote CW, so you can send with your own key or paddle to a remote station. Works with any radio brand. morconi.com ↗
N4PY Software Rig control and station integration software that supports FLEX-6000 and FLEX-8000 radios, including MultiFlex. Ties in amplifiers such as the PGXL, autotuners, panadapters and controllers like FlexControl. n4py.com ↗
HaliKey A small USB adapter from Halibut Electronics that connects your own paddles or a PTT switch to the computer for remote operating. Works with SmartSDR for Mac and iOS, PocketSDR, AetherSDR and NetKeyer, and gives PTT in SmartSDR for Windows. electronics.halibut.com ↗
Skimmers and IQ tools
Decoders and analyzers that use the radio's DAX IQ streams.
SmartStreamer4 A free Windows companion for SmartSDR 4.x that streams DAX IQ into CW Skimmer, with instances synced to your panadapter. It also sets up and launches WSJT-X, JTDX or WSJT-Z for each slice. wx7v.net ↗
SDC A suite of station programs by UT4LW, including CW, RTTY and BPSK skimmers and a telnet server that combines spot sources. Connects to FlexRadio directly through the SmartSDR API. lw-sdc.com ↗
IQSkimmer A multi-channel CW skimmer for FlexRadio DAX IQ streams that decodes every CW signal in the span at once. Runs natively on macOS, Windows and Linux. github.com ↗
CW Skimmer A multi-channel CW decoder that decodes every signal in the passband and labels the waterfall with callsigns. Spots are shared through its built-in telnet cluster server. dxatlas.com ↗
Logging and contesting
Loggers that read frequency and mode from the radio and log your contacts.
N1MM Logger+ A free contest logger for CW, phone and digital modes, used by contesters worldwide. n1mmwp.hamdocs.com ↗
N3FJP Software Amateur Contact Log for everyday logging plus a family of contest logs, including ARRL Field Day, from Scott, N3FJP. Its Flex API rig interface connects to the radio over your network, with no CAT cable or virtual port needed. n3fjp.com ↗
DXLog A free contest logger by 9A5K that supports more than 500 contests and is a favourite for SO2R. Its FlexRadio options include SO2V operation and playing its voice keyer through DAX for remote operating. dxlog.net ↗
SliceLogger A full-featured logging program built to work with SmartSDR radios and the Power Genius XL. github.com ↗
OpsLog A free logger for Windows, Linux and macOS with native FlexRadio control. Also works with the Power Genius XL, Tuner Genius XL and Antenna Genius. github.com ↗
MacLoggerDX Mac logging and rig control software that filters DX cluster spots, tunes your radio to them and turns your beam. Includes WSJT-X integration. dogparksoftware.com ↗
Swisslog Windows logging software with rig control for FlexRadio and other brands, plus LoTW and eQSL sync. Logs contacts from WSJT-X, JS8Call, MixW and fldigi. swisslogforwindows.com ↗
Wavelog A free, open-source, self-hosted web logbook, so you can log contacts from anywhere. wavelog.org ↗
QLog A free, open-source logbook for Linux, Windows and macOS with station control, award tracking and QSL workflows. github.com ↗
Digital modes
Soundcard and digital-mode programs that work with the radio through DAX and CAT.
WSJT-X Weak-signal digital-mode software from K1JT and the WSJT development team for FT8, FT4, JT65, JT9, Q65, MSK144, FST4 and WSPR. Free and open source for Windows, Linux and macOS. wsjt.sourceforge.io ↗
JTDX A free derivative of WSJT-X for FT8, FT4, JT65 and JT9, with decoder changes aimed at busy HF bands. sourceforge.net ↗
MSHV Digital-mode software by LZ2HV for FT8, FT4, MSK144, Q65, JT65 and meteor scatter modes. sourceforge.net ↗
JTAlert Audio and visual alerts for WSJT-X and JTDX decodes. hamapps.com ↗
GridTracker Reads WSJT-X traffic and your logbook and shows activity on a map, to help you find new grids and DX. gridtracker.org ↗
JS8Call JS8Call-Improved, a community-developed version of JS8Call for HF digital messaging. Fully compatible with earlier JS8Call versions. js8call.com ↗
fldigi A multi-mode soundcard modem for PSK, RTTY and many other digital modes. Part of W1HKJ's suite with flrig, flmsg and flamp. w1hkj.org ↗
MMTTY A free soundcard RTTY program for Windows by JE3HHT. hamsoft.ca ↗
MMSSTV A free soundcard slow-scan TV program for Windows by JE3HHT. hamsoft.ca ↗
FreeDV Open-source digital voice for HF, led by the Radio Autoencoder (RADE) mode. Free apps for Windows, Linux and macOS. freedv.org ↗
CwGet Decodes Morse code to text through your sound card. dxsoft.com ↗
Building something that works with Flex?
The FlexRadio API lets you build your own software and hardware for FlexRadio transceivers.
Disclaimer. The products listed on this page are developed, sold and supported by independent third parties, not by FlexRadio Systems. FlexRadio does not test, endorse, warrant or support these products, and makes no representation that any of them will function as described, operate with your radio, firmware or software version, or remain available. Use of any third-party product is entirely at your own risk. To the fullest extent permitted by applicable law, FlexRadio Systems disclaims all warranties, express or implied, including any warranty of merchantability or fitness for a particular purpose, and shall not be liable for any damage to equipment, loss of data, or any direct, indirect, incidental or consequential damages arising from the use of, or inability to use, any product listed here. Questions, support requests and warranty claims should be directed to the product's developer.
Accept
Pay Over Time
