SmartSDR Version v4
The SmartSDR v4 Basic License is free for every Aurora, FLEX‑8000 and FLEX‑6000 radio. It modernizes your station with a more reliable foundation and a clear path to innovation — without changing how you operate today. SmartSDR is for Windows platforms. Windows 11 is highly recommended as Microsoft has ended support for all previous versions.
What you get with SmartSDR v4.x (Basic)
- No‑cost upgrade for all FLEX‑6000 and FLEX‑8000 owners
- Ongoing stability and bug‑fix updates in 4.x, at no charge
- One current release
- Works across your existing ecosystem (where hardware allows)
New feature unlocks are optional. If you’re happy with the core experience and fixes, SmartSDR Basic has you covered.
Two optional ways to go further
1) SmartSDR+
The feature add‑on for power users.
- Unlock all new features released for 365 days from the day you activate SmartSDR+.
- Keep everything you unlocked—those features remain available and do not expire.
- Renew whenever it makes sense for you to capture the next wave of capabilities.
- Perfect for operators who want steady, meaningful upgrades without fuss.
- Features stay licensed to the radio. If you sell the radio, the features go with the radio.
How it works (at a glance):
- Day 0-30: Activate SmartSDR+ Early Release — immediately unlock all new features available at launch.
- Approximately on Day 30: SmartSDR+ Early Access features become available for all SmartSDR+ subscribers — unlocking for anyone with an active plan.
- Days 32–365: Continue to receive every new feature released within your active year.
- Day 366+: Your radio keeps all those unlocked features; you can re‑activate later anytime to get the next 365 days of innovations.
2) SmartSDR+ Early Access
For operators who always want the latest — first.
- Get new SmartSDR features ~30 days before general availability.
- Shape what ships by sharing feedback directly with the team during the initial 30-day Early Access window.
- Upgrade from SmartSDR+ for guaranteed early access to the next set of feature unlocks. SmartSDR+ Early Access replaces SmartSDR+.
SmartSDR+ Early Access accelerates as you gain access to new capabilities. SmartSDR+ determines which features you keep long-term.
Quick Comparison
| Capability | SmartSDR v4 (Basic) | SmartSDR+ | SmartSDR+ Early Access |
| Price | Free — Included with your radio | $199 / 365 day window | $299 / 365 day window |
| Bug Fixes | Included in v4 | Included | Included |
| New Feature Unlocks | No | All features released during your 365-day window | x |
| Use new features 30 days before public release | x | No | Yes* – see note below |
| Keep features after window closes | x | Yes | Yes |
*Note on SmartSDR+ Early Access: It gives you a head start on upcoming features. SmartSDR+ users gain access to the new features approximately 30 days later. All features are available for the life of the radio once enabled.
Click to enlarge. Rotate screen to view for mobile.
How to Purchase SmartSDR+ or SmartSDR+ Early Access
Windows PC
- Upgrade to SmartSDR Basic
- Start SmartSDR Basic
- Select Radio Settings
- Select Radio Tab
- Select either “Get SmartSDR+” or “Get Early Access” (only choose 1 or the other)
Maestro or M Model
- Connect your Maestro or M model to you radio
- Select Menu
- Select Radio Tab on Left side
- Scroll down to “License Info”
- Scan the QR code with a mobile device
- Follow the instructions on your mobile device
Why this model?
For years, major “version jumps” made it hard to plan and harder to match your expectations. With SmartSDR v4 we’ve:
- Separated fixes from feature unlocks so your radio stays stable without extra cost.
- Given you control over when to add features—activate SmartSDR+ only when the new capabilities are right for you.
Opened an earlier lane for enthusiasts via Early Access to help us deliver better features, faster.
What stays free?
1) Installing SmartSDR 4.x.
2) Bug fixes and reliability improvements within the 4.x line.
3) Core licensing—no change to how you run day to day.
Notes:
FLEX‑6000 and FLEX‑8000 are supported. Features and availability may vary by hardware. Some features will only be available on FLEX-8000 series.
SmartSDR+ and SmartSDR Early Access is for Windows platforms. Windows 11 is highly recommended as Microsoft has ended support for all previous versions.
If you add SmartSDR Early Access while SmartSDR+ time remains — the new Early Access term replaces your existing SmartSDR+ period starting from the purchase time of SmartSDR Early Access. Remaining SmartSDR+ time does not carry over or receive a prorated credit.
If upgrading from v1 to v4 — you will not have access to SmartLink or MultiFlex. Access to SmartLink or MultiFlex would require you to purchase SmartSDR+ or SmartSDR+ Early Access.
If upgrading from v2 to v4 — you will not have access to MultiFlex. Access to MultiFlex would require you to purchase SmartSDR+ or SmartSDR+ Early Access.
- All FLEX-6000 and FLEX-8000 radios must have internet access to complete a purchase.
- If your radio is connected directly to your PC with a single Ethernet cable, you’ll need to provide a path for the radio to reach the internet.
- Radios showing an IP address that begins with 169.x.x.x indicate no internet access and will require network configuration before proceeding.
All purchases of SmartSDR+ and SmartSDR+ Early Access are final.
