RRC-SMB-SBC- Single Bay Charger for the RRC2054-2
Single bay battery charger for the RRC-2054-2 battery.
  • AC power supply included
  • Optimized charging process for RRC batteries
  • Longer cycle life
  • Faster charging
  • Simple Operation.
Required to charge your RRC2054-2 outside of your Maestro C. Not required if you keep your battery installed in your Maestro C.
Specs
  • Weight: 32 oz
  • Width: 12 in
  • Depth: 6 in
  • Height: 9 in
 Do not open or dismantle a battery.
 Do not expose the battery to heat or fire. Avoid storage in direct sunlight.
 Do not short-circuit a battery.
 Do not store the battery haphazardly in a box or drawer where they may short-circuit each other or be short-circuited by
other metal objects.
 Do not remove a battery from its original packaging until required for use.
 Do not subject the battery to mechanical shock.
 In the event of a battery leaking, do not allow the liquid to come in contact with the skin or eyes. If contact has been made,
wash the affected area with copious amounts of water and seek medical advice.
 Do not use any charger other than that specifically provided for use with the equipment. See the battery charger technical data sheet here.
 Observe the plus (+) and minus (–) marks on battery and equipment and ensure correct use.
 Do not mix batteries of different manufacture, capacity, size or type within a device.
 Keep the battery out of the reach of children.
 Keep the battery clean and dry.
 The battery needs to be charged before use.
 Use only the battery in the application for which it was intended.
 When possible, remove the battery from the equipment when not in use.
 Do not store a battery longer than 1 month in a discharged state.
 Do not storage a battery longer than 1 year without recharge.
 The battery must be recycled or disposed of properly.
